ALL OFF 96 GSR
-alternator with both mounting brackets
-p/s pump with brackets
-full under hood a/c system
-radiator with both fans
-flywheel cover
-tranny to motor brace (by oil pan)
-metal motor mount bracket (bolts to block drivers side has 2 long studs)
-flywheel
-header
-stock cat back exhaust, pretty good condition, mid pipes a lil rusty
-rear motor mount that bolts to the subframe
-stock tow hook
-slave cylinder
-dip stick
-4 rims with center caps on kuhmos 2 good tires 2 need changed 300+ shipping
OFF JDM H22a
-2 foot clutch line ( hard line and flex line that bolts to slave cylinder)
-full header and heat shield
-all motor mounts except for rear tranny bracket, very clean
-stock p/s pulley
-a/c compressor
-egr system
-a couple bypass valves
MISC
-d series starter
-d series stock header w/ o2 (off del sol s)
-plugs from jdm h22 wiring harness (2 pin, 3 pin, main harnes connections etc.. from under hood)
-hf junkyard turbo manifold 50shipped
-4-390cc dsm peak and hold injectors out of an auto turbo dsm 45 shipped
-6-440cc supra injectors peak and hold (top feed style out of older supra, not side feed) 75shipped
-d16z6 cam
-craftsman air tools, still in box (1/2 imapct, 3/8ratchet, air hammer) 175 shipped
-90-93 integra drivers side abs axle
-2 86-89 integra pass. side axles basically new
-92-95 civic d series drivers side mount
will partout anything, i just want this stuff outta my garage everything is obo
-flywheel cover
-flywheel
-header
-stock tow hook
-slave cylinder
-dip stick
OFF JDM H22a
-stock p/s pulley
-a/c compressor
-egr system
MISC
-d series starter
-d16z6 cam
