fs: injectors, vafc, xmod, mbc,axles
hybridsol
manual boost controller, with bracket, selling cause i want and elctronic bc best offer
4-390cc peak and hold dsm injectors, person i got them off of said they were 450s but they are clearly 390s 45shipped
xmod, skyline, suspention, stage 2 motors, 8batterys and quick charger, carrying case, everything. Played with it for like 5 mintues and got hella bored because its nothing like my gas powered r/c. cost me like 120 i'll go for 90shipped
4-440cc peak and hold supra injectors (7mgte) no longer need,i got 870s hehe. asking 55shipped
apexi vafc, clean as hell, no scratches, i have the box and everything if you really want it, barely used comes with everything shown, which is all you need to make it work and get it mounted 215shipped
top: drivers side 90-93 teg ls axle w/abs ring, about 300 miles on it
middle:90-93 teg ls axle passenger side, about 4 miles
bottom:88-89 teg ls axle passenger side, about 100miles (lil shorter than 90-93)
best offer on all these
Originally posted by jdmcrx89@Jul 18 2004, 11:09 PM
can those 440's be used on my gsr, or do i need saturated?
[post=365059]Quoted post[/post]​
You'd need a resistor box and the injector clips.
your stock clips wil work, you'll just need to add a resistor box, fairly easy, its a 5 wire hook up. oh also the vafc guy flaked, and i've also got an obd1 chipped p28 5800vtec and 9000rev limit
same thing for 390's? needa resistor box? how much do one of them run. if its fairy easy ill take the 440's
shoulda said earlier the axles and the 390s are sold. resistor boxxes go fo rlike 20-25shiped on h-t allday. I also just got some obd1 (dsm) injector clips with like 5-6 inch pigtails on them, looking for 25shipped. oh the 440s will go in fine, and the resistor box hook up, there are write ups on h-t, and prly on this site also, its fairly simple
