fs:schwitzer aka borg warner turbos
kowcain
im located in charleston
you can pm me.
price - 600 each or trades for sohc stuff
got these from a uncle that works for a big name engine company, they ran them for 5min for testing a motor.
just seeing what i can get for them would take trades lmk.. here are some pictures.
Model spec.: S200W
Turbo maker: Schwitzer
Orientation α (compressor housing): 252°
Orientation β (turbine housing): °
Axial play min./max.: 0,05/0,1 mm.
Radial play min./max.: 0,41/0,55 mm.
Clearance min./max. (compressor end): / mm.
Clearance min./max. (turbine end): / mm.
Power kW/hp: 330/443 at 2100 rpm
cooling - oil fed
what it came off of
Engine: BF6M1015C
Engine displacement: 4.91 litres
Fuel: diesel
hopes some of this helps.
are those exhaust flanges T-4? Could you give a dimension on the studs, and how thick it would be say if it were mounted infront of a block? Just trying to see how much room I would need between the block and radiator.
Thanks
E
