94_gs-r
can you say 260 whp N/A??
motor has 3,000 miles
head reground everything resurfaced
block bored and honed to 81.5mm
arp rod bolts
acl rod bearings
11:5:1 compression
molley coated pistons
crank and rods shotpeened and micropolished
rotating assembly rebalanced
gsr intake manifold
new type r oil pump
itr water pump
new timing belt
everything done by finishline engineering
stock injectors
includes fidanza flywheel and 6puck kevlar clutch
includes distributer also
does not have tranny or ecu or wiring harness
motor does not leak or smoke ran perfect
broken in with 30 weight after break it ran with royal purple 5w30
ASKING 2,000 plus shipping to where your located
contact me at bcacuraintegra@yahoo.com
leave email adress
selling cause i bought another motor
arp rod bolts
acl rod bearings
11:5:1 compression
gsr intake manifold
new type r oil pump
itr water pump
new timing belt
stock injectors
leave email adress
