fastnlow93teg
mitsu TE04H turbo for sale, specs are as follows:
-Model: MHI TE04H-13C
-OE Part #: 49183-2010, 49183-2210, 49183-1000
-Wastegate setting: ~7 psi
-Compressor Trim: 50
-Exhaust turbine dia.: 51mm
-Oil and Water Cooled
-Recommended applications: 150-250 hp, 1.5L-2.2L motors
Turbo is in great shape, no shaft play and no broken/bent fins. The only reason im selling this turbo is beacuse i need something larger for my setup. I have an adapter plate for this turbo to make it fit any standard T3 manifold, which will be included with this turbo.
Item number: 180018068867 on ebay. PLus pics
