FS: tons of Honda/Civic/D-series/other stuff
stmotorsports
Off to a good start on spring cleaning- I still have alot of this stuff laying around & don't really have any plans for any of it...
All prices are /BO + shipping so hit me up with your offer and zip # so I can see how much it will be to ship- I have a FedEx acct so I can get stuff shipped pretty cheap
There are still no jobs in this area so help me finance my projects!! :D
ps- I use the same name on eBay as my username here if anyone wants to check my feedback
Y8 intake manifold + 60mm prelude tb - manifold was auto converted to manual, is gasket matched at tb and head, runners honed/polished all the way up- not just the 1st couple inches! Comes with F22 Accord IACV, stock Y8 fuel rail/regulator, brand new oem Honda tb + manifold gaskets. ** PICS HERE ** $150/bo
K24A4 head - complete w/all valvetrain, cams + vtc actuator. May need to be milled(??) $125/bo
JDM D15B high compression shortblock - complete jdm swap bottom end with BRAND NEW 2001+ gx pms pistons and rings. I used a few different compression calculators and this setup should give ~11.5:1 with a d15b/z6 head and head gasket. $375 FIRM ~> THAT'S NOT MUCH MORE THAN YOU'D PAY FOR JUST THE PISTONS AND RINGS AT A HONDA DEALER!! :eek:
- OR -
JDM D15B shortblock -
complete except for pistons. Great for a project requiring custom pistons for any reason. AND NO the stock pistons weren't fried or damaged in any way, I just needed them for my project motor. I don't want anybody thinking that I'm trying to pawn off a motor that was blown up or anything, the motor ran 100% when pulled and was compression tested before it was disassembled. $150/bo
JDM D15B cam - $75/bo PENDING SALE
Z6 trans (DelSol Si)- VGC, no grinds when using GM Synchromesh fluid $150/bo
v v v v v v v v v v v v
y7 trans - complete but needs front bearings $100/bo
DOHC d-series head - complete w/cams, valvetrain, intake, tb, all sensors, ECU, inside+outside wiring harness sections (cut in middle-don't ask), etc- came out of an '88 integra, not sure if its a d16a1 or d16a8/9. Basically the USDM version of the JDM DOHC ZC $100/bo
2- 13"x5" steelies w/ 185/60/13 Bridgestone race tires (r-compound) - still probably a season left on them $50/bo
1- stock crx left wheel - 14x5 SH3 45mm offset, needs tlc $15/bo
D-series auto flywheel - mint cond fresh off of a jdm d15b, with hub ring and bolts $20/bo
D-series auto flywheel - came off of an '02 D17A2 $15/bo
'01+ D17 misc. mounts, brackets, fittings, etc - ?? send requests
PM3 timing belt - fits '88-95 civic std/cx/dx/lx/wv, crx dx/hf, delsol s. Only a few hundred miles on it $10
P2E timing belt - fits d16y5/y7/y8. Only a few hundred miles on it $10
(4)Falken Ziex 225/50/15s - only have less than a few hundred miles on them, one is worn bald on the very inside edge $75/bo
'92-'95 cx 5-spd trans - excellent cond, no grinds ever, etc- great for turbo/drag hybrid or leave as is for AMAZING mpg!! ;-) $75/bo as-is (stock), $125 with si final drive included
'92-'95 dx exh manifold + 'a' pipe - rear pipe flange reclocked to bolt up to B-series (itr) cat + catback $25/bo
EG cx valve cover - Excellent Cond. $15/bo
OBD2 cx distributor - EG base w/ OBD-2 internals $35/bo
stock '93 cx manifold - complete, all sensors, tb, fuel rail/injectors $35/bo
stock USDM civic airbox/tube/resonator box + all related stuff - cool black low gloss finish + already broken in OEM low flow filter, AWESOME for low performance applications $275/bo <~ nobody has noticed this?? rofl
P2E ecu (#1) - manual trans, came off running engine $35/bo
P2E ecu (#2) - auto trans, not sure if good or not. Buy for parts, tuning, experimenting, etc. No bitching if DOA!! $15/bo
dx lower rad hose - only on for like 3 months $5
z6 lower timing cover $15
OEM z6 starter - also fits ?? $30/bo
OEM z6 power steering pump $30/bo
PM5 head gasket - only a few hundred miles on it. Fits various apps, contact me if not sure $5/bo, free with other items
cx crank pulley $10/bo
Underdrive pulley - silver finish, w/ belts $75/bo
EG dx trailing arms - complete w/hubs, brakes, ebrake cables- Make offer
Z6 crank/rods/pistons - all GC, came out of good running engine Make offers
GSR 14mm rear sway bar - BRAND NEW **SOLD**
LS 13mm rear sway bar $20/bo
B20 stock header + heatshield $25/bo
ITR stock exh manifold/A-pipe/heatshields $35/bo
F22A1 Engine complete - valve cover to oil pan, intake/exh manifolds, all sensors, accessories, brackets, hardware, etc etc ~108,000 miles $350/bo <~ PICS UP SOON
F22/H22 5-spd trans - shifts good, no grinds. Brand new clutch. Fits 90-97 Accord/Prelude $200/bo <~ PICS UP SOON
^^^^ $450/bo TAKES BOTH ENGINE + TRANS
F22A1 Intake manifold complete - w/ tb, all sensors, fuel rail/injectors/pressure regulator, good EGR, thermostat housing, etc etc $45/bo <~ PICS UP SOON
F22A4/A6 OEM 4-2-1 header + heatshields $35/bo
EG coupe oem rear bumper cover - good cond, red $35/bo
Thule roof rack - fits 90-93 Accord, others ?? $35/bo
POSSIBLY AVAILABLE: Hybrid EG trans complete - civic cx 1st-5th gears, Si 4.25:1 final drive. GC, no grinds ever. I can ship it complete all assembled with all work done (ie-drop in and go), or if you want to save a couple bucks I can ship the cx trans as is with the si final set separate (ie-DIY build). Contact me for actual ratios and pricing
+ MORE TO COME SOON....
thanx guys B)
there you go all- thumbs up from 2 admins, what else do you need?
free biskit when u be ordrin a large orang soda :fosho3:
