FS: TONS of parts!!!
Hi how much for the VTEC valve cover( I assume it is B16A/B18C) and the ARP flywheel bolts posted to Australia 3806, USPS is fine.
what are the specs on the turbo? how many miles on it? any shaft play or does it burn oil? what bolt pattern is it? pm me thanks
IM OPEN TO REASONABLE OFFERS!
FIELDS VTEC CONTROLLER.............$100
JE 84mm 12.2:1 pistons appr. 75miles.........$200
Cometic Exhaust Gasket............................$ 28
Allen Head Valve Cover Bolt kit.................$16
Oil Catch Can Kit ................................... .....$20
Fuel Pressure Gauge kit ............................$25
Rear Main and Timing Cover Seal ...........$27
Hondata C5 Intake Mani Gasket ..............$50
Turbo Oil Iine Kit ................................... .....$53
Darton 81.5mm Sleeves ............................$350
ARP Head Studs ................................... .....$120
Rear Main Seal ................................... ........$17
Light Weight Crank Pulley ........................$30
KMS Cam Seal ................................... ........$12
GSR Cams ................................... ............... $115
T3 Turbo Gasket ................................... ......$8
T3/T4 Turbo ................................... ..............$145
Lower Motor Mounts ................................... $60
Polyurthane Motor Mounts .........................$185
LS Crank ................................... ............... ...$100 (used 80k)
Vtec Waterpump ................................... .....$85
VTec Valve Cover.............................. .........$50
OEM GSR Manifold w/ throttle body.................$45
