fuel cutting out while driving
Discussion in 'HYBRID -> ED-EF / DA' started by aasarsak, Dec 1, 2008.
  1. aasarsak
    aasarsak New Member
    has anyone had to deal with this problem or have any idea where to start looking for a solution? I have already run a diagnostic on the main relay, and it is perfectly good.
    any time I'm at constant speed, constant throttle, the fuel cuts out. If I apply a little more throttle pressure, the mixture goes rich, but as soon as I resume constant throttle and and speed, the fuel cuts out again.
    My guess is a short somewhere, but I'm not exactly certain how to diagnose this bugger.
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    you problem sounds like its in you ecu, find a buddy with the same ecu as you and swap it in, see if it solves your problem.
