Fuel In oil b16a2 crx
Discussion in 'HYBRID -> ED-EF / DA' started by Onefry, Jun 23, 2007.
  1. Onefry
    Onefry New Member
    Hey, my oil smells like fuel in it...one of my friends auctually tasted the oil and said that he tastes fuel lol
    i had like 3 other people say that they smell gas in oil
    I did a compression test Cyl1-160psi cyl 2 ~175 cyl 3 ~175 cyl 4 ~175
    I heard 160 is normal but could it be that i'm getting blowby?
    the other kids thread about his cel going off then he lets off his gas...that what I got...i cant scan for codes because theres no dlc hooked up but im guessing its my oxygen sensor...
    could this make my engine run rich causing gas in the oil?
  2. invisibledemon
    Tn
    well im not sure about the a2 but on the obd0 you check the codes by looking at the ecu and counting the blinking lights. could just be some blowby in that first cylinder. but if you cant check the CEL then your in for a lot of guesswork, which means $$$$$$
  3. Onefry
    Onefry New Member
    yeah...theres no led on my ecu....so im stuck trying to jump the mil wire with something?> do i ground it?
