dilbeckskate
infamous
ok guys as you know im doing a high compression dohc zc swap in the 79 civic, its getting dropped off this month at the fabrication shop to get the mounts made, at first I was going to run it on carbs but now have decided im going to do EFI , I have the correct obd0 PG7 ecu and the correct obd0 distributor and intake sooo its going to be easiest going obd0 with what I have, soo looking for info out there if im correct I need to use any 88-91 civic mpfi engine harnees or a obd0 da integra engine harness, does anyone know If I can wire the harness not to use the dash/chassis harness and used stand alone ? I have diagrams saved on a old hard drive I need to pull from my crx days but im hoping I can use just a engine harness or I have to find a donor car , any input would be appreciated
