Fuel injector questions?
Discussion in 'Civic and CRX - EF' started by 34diesel34, Nov 22, 2009.
  1. 34diesel34
    34diesel34 Import Tuner
    USA
    I'm putting my B16a in my 91 crx si tomorrow. It's the OBD1 sir2 B16a. I've already been converted to OBD1 with the sohc vtec (A6 block Z6 head)that I'm pulling out of the car. I was using OBD0 injectors with this setup. I'm planning on using the OBD1 injectors that came with the B16 I have. Do I need to remove my resistor box now, or do I keep using it with the new setup ? Will the stock crx si injector plugs plug into the OBD1 injectors? please help:huh:
  2. 89hatchd15b
    89hatchd15b now its a 91
    Acton, CA
    remove the resistor box and dremel the plugs to fit the new injectors or the injectors to fit the plug, I can't remember which it is.;)
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    yes they will
  4. 34diesel34
    USA
  5. blasterman87
    blasterman87 New Member
    yup, they should plug in you might have to modify the plug, or you can use your old injectors, there the same rate/size 240cc
  6. 34diesel34
    USA
    So you're saying my D16 fuel injectors will work on the B16?:eek:
  7. blasterman87
    sure will there the same, and with those you wont have to delete the resistor box. but thats easy to do. either way its simple
  8. 34diesel34
    USA
    They dont fit:mad::mad: Thank god the engine came with injector plugs. I can use those and cut the ones on my factory harness off.
  9. blasterman87
    just use the stock injectors..
  10. 89hatchd15b
    Acton, CA
    don't mean to be mean but I told you they wouldn't fit
