Hey guys so I have a b18a swapped into a ef civic and when I started the car It would run for about 30 seconds then die, after awhile I pulled the plugs to test compression of the 3rd piston and there was gas/oil all over them. Gas has gotten into my engine aswell. This freaked me out so I checked the lines and everything running from the injectors and Im pretty sure its fine but Idk whats going on. Should I get a integra injector module? I dont remember reading about needing one but Im honestly stuck on this.
