My setup is an LS motor with all the stuff waiting to be installed!!!
My cr should be around 11.4 to 11.7 when I finish depending on the head gasket I choose......Any way my question is, do I need more fuel? Bigger injectors that is.
I got a good deal on an EK 9 Civic Type R fuel rail and Injectors, and I want my
motor to look bone stock. So I figured they would be perfect! What psi should I run after I raise the compression and change the injectors? I know that my stock LS injectors suck after 35 psi and I start to loose power.
I need some facts or tips!
