fuel injectors
Discussion in 'Engine Building' started by Bobby17772, Sep 12, 2009.
  1. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    does anyone know what the flow rate of stock d15b2 injectors are, the dpfi, because I would imagine that they must be higher then the mpfi ones because you're running an engine on only 2 injectors, but that just may be my thinking.
    thanks
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    they are actually smaller on dpfi than mpfi..smallest mpfi is 240cc(which is what the civic.crx.integra.and all that use...
    the dpfi civic/crx use 180cc injectors
  3. Bobby17772
    Enfield, CT
    no kidding, I'm actually shocked with that, because you would think they would have put bigger ones in seeing that it only uses 2 injectors and not 4.
  4. Bobby17772
    Enfield, CT
    I would give you rep but it said I have to spread more around first so +1 hypothetical rep
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
