Fuel Injectors..
Discussion in 'General Tech and Maintenance' started by BLKCIVICPN0I, Dec 18, 2004.
  1. BLKCIVICPN0I
    BLKCIVICPN0I Member
    LBC
    Is it worth getting your injectors cleaned or should I just buy a new set? If I do get them cleaned, does anybody know where I can get em cleaned in the Torrance, Ca area?
  2. SOHCD16y8
    SOHCD16y8 Junior Member
    Northwest Indiana
    Might as well just buy new ones especially if you have some engine upgrades
  3. beerbongskickass
    beerbongskickass Senior Member
    Longview WA
    I forgot the name of the site and I am too lazy to check, but if you search honda-tech you should be able to find it. Tha name is on the tip of my tounge...
    It's like $11 per injector to have them cleaned and balanced.
  4. pissedoffsol
    stock injectors? throw 'em out and pick up another set online.
    aftermakrket/larger, get 'em cleaned
  5. psi
    psi Junior Member
    You can use seafoam to clean them. You just add the recommended amount to the fuel tank and off you go. Just make sure you get the right one for your specific application.
    They are found at most automotive supply stores like AutoZone and such.
