hi, i have F22B DOHC from Prelude BB5 (5 gen, obd2a, no vtec, 160 hp)
ecu is P28 chipped by Phearable for 240cc injectors
eld is off
o2 is off
IAB make from VTEC
compression test 12, 11.3, 11.5, 11.5 kg/cm2
idle 850rpm
injectors 15.7 Omh
resistbox is cut
i have problem with fuel, if i set on fuel pressure regulator 5 kg/cm2 then car run fine, if i set the 3 kg/cm2 run is slowly
pls help resolve probleme
ps: the fuelmaps and injectors of ecu P5L (obd2a f22b dohc) and P39 (obd1 f22b dohc) is diffirent?
the car is Accord CD3 (JDM, similiar CD5)
eld is off
o2 is off
IAB make from VTEC
idle 850rpm
injectors 15.7 Omh
resistbox is cut
