fuel issue
frieseb
Just installed a d16z6 and it isnt throwning any codes. I purchased a wiring harness from rywire for the swap. If the car sits for 20 min it will run for about 2 seconds then die.When checking the plugs the only one getting wet is the #2 plug thats it also the timming is correct. Someone please help me. TIA
Stock distributor, p28 ecu, and how would I go about testing the injectors to see if they are clogged? If they are clogged how can I fix them? thanks
From what I understand to test your injectors leave them plugged in but pull them out of the fuel rail and lay a towl or somthing infront of the injectors and start the car. Observe the fuel being sprayed out of the injectors. If they are plugged check out http://www.rceng.com/service.htm for cleaning services. Go back and check your wirring agian maybe. I hope that helps some.
