Fuel Management for B18A turbo...
RFHOMI2U
I have a B18A with a 50 trim T3/T4 and TONS of aftermarket parts. I will be running 8psi daily on stock internals, fully re-built, and front-mounted.
I have AEM fuel rail, Stock injectors, JG Victor-X manifold, AEM FPR, and Walbro 255lph fuel pump.
For electronic management, I was thinking of just using an S-AFC. Will that work? Do you think that's enough fuel managment? I have a friend with a ZC turbo 4psi and just an AFC (none of the shit I have) and he is doing fine. Will I be ok?
yea a safc should be fine for what you want...or get fmu, they are good for around 10 psi depending on the turbo....
safc will not be enogh with stock injectors.
you need either an FMU with the stock injectors
or
vafc/safc + 440-450cc injectors
or
hondata/your ems here + sized injectors
