fuel management for LOW LOW boost
Discussion in 'Forced Induction' started by SLOWdelawareEG, Mar 4, 2007.
  1. SLOWdelawareEG
    SLOWdelawareEG my cars go fast
    hilton head island, sc
    :confused: :confused: :confused: :confused: :confused: :confused: :cool:
    my car is a 95 hatch w/ d16z6. just got a cheap ebay turbo kit and am using a tial wastegate w/ .25 bar spring(3.5psi) for max adjustability. is 3.5psi is safe to run w/o fmu or e-management.. im just wonderin cuz i want to put it on now and run low boost b4 i get fuel enrichment
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    I dont recommend any boost without fuel enrichment. I would just wait and do it right. There is not reason to jepordize a good engine for nothing. Plus without proper fuel enrichment there will be minimal power gains. I would recommend getting some professional tunning using CROME or hondata since you already have a obd1 setup. That way you will get the most power and reliability for how much boost you are running. FMU suck balls I would never use one. So do piggyback computers such as a emanage and vafc.
  3. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    if you don't go over 2 psi you'll be fine.
  4. vtec777
    vtec777 Junior Member
    up 1.0 bar boost is good......:)
  5. turbo sol
    WHAT?!?!?!?! you WILL NOT have a sufficient fuel supply, and you'd have to tune the ecu or you'd be popping CELs and the engine wouldn't run right.
  6. vtec777
    must be setting ecu first...got a big injector....:)
  7. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    I cant understand WTF this dude is saying :lol:
    Buying everything to tune with Crome yourself, including a Wideband, will cost the same as a Emanage with the injector/ignition harnesses. Crome works excellent and is pretty easy to learn to use. If you have a common car and setup there's a million basemaps on pgmfi.org for you already to get you close.
  8. boostin4fun
    Omaha
    The factory map sensor cant even read boost levels that high. It would definetly be choking and throwing CELS. I dont even think 14psi is a good idea on a factory bottom end, not that people dont do it all the time. You just have to weigh power/reliability. But if you are wanting to run boost that high make sure it is setup right. By that I mean a fuel pump, injectors, 3 bar map, and professional tunning to get it to run right.
  9. boostin4fun
    Omaha
    This isnt even intelligent enough to warrant a response from me.
  10. turbo sol
    no...unless you want pieces of rod and piston in the oil pan... it would enevitably blow into a million pieces... literally.:D
  11. Turbo&Auto
    East Burg, PA!
    Depends on the size of the turbo. I ran 17psi on the F series for awhile, it did brick after a bit but it also had 200K on it :)
  12. SLOWdelawareEG
    look you f-ing nerds........i asked a simple question: can u run low boost w/ no fuel enrichment. NOT 1bar(14.7psi) I SAID 0.25bar(3.63psi). just answer the question. i dont care about crazy claims of 17 psi on a f series accord or tuning options with chrome or hondata or any of that other bull. all i wanted to know is can i bolt on a snail, regulate low boost and go. THATS IT!!! JUST ANSWER THE QUESTION
    ps...................someone needs a girlfriend:(
  13. Turbo&Auto
    East Burg, PA!
    You need to learn how to read NOOB.....
  14. turbo sol
    i already answered your fucking question!:D
  15. Turbo&Auto
    East Burg, PA!
    Ban this asshole. He comes in asking for help, we give it, then we engage in a lil discussion about something and he bugs. :ban:
  16. SLOWdelawareEG
    youre a fucking nerd---try to cope
  17. Turbo&Auto
    East Burg, PA!
    I am and it makes me a lot of money :) You on the other hand are NOT very intelligent and it shows.
  18. turbo sol
    :rotflmao:
    so who wants to ban this douche? i'm in...
  19. Turbo&Auto
    East Burg, PA!
  20. turbo sol
    :newbie: :ufucktard:
    T&A knows more shit than you could ever even hope to wrap that little head of yours around... the man is smart. no doubt.
