fuel management
04elcblue
stock b18 a1 turbo fuel /timing managment ? I want to be able to tune myself with out spending to much over 1k.
well if it's an b18a1 and you're in an ef, if you're running obd0 use TurboEdit, it's very easy to use and pretty self explanitory with a lot of things. if you want to tune it yourself the biggest and most important tool you'll need is a wide band o2 sensor, boost/vacume gauge, and a tach, to monitor everything then just make adjustments from there on your tuning
