fuel management ?
sryan3838
I am looking to turbo my 98 3 dr wondering what the best fuel management i could use would be. Is there a certain brand of FMU prefered over others? do i need a high pressure fuel pump? Im only looking to run about 8 lbs boost should i look into injectors or will my stock equipment be ok? This is on a stock D16Y8. Thanks for looking
OBD2>OBD1 conversion harness, run a chipped OBD1 VTEC ECU and have it tuned on CROME, Neptune, Uberdata, etc. for your setup. Stock injectors will probably not work too well, I'd at least source some DSM 450's. The stock fuel pump should be fine but that is highly dependent upon tuning.
