fuel problem please help!!!
Discussion in 'Civic and del Sol - EG and EK' started by rkwoos12, Apr 6, 2009.
  1. rkwoos12
    rkwoos12 New Member
    Kentucky
    ok so i was driving my 94 civic coupe and i was geting a little below half a tank and i started to notice my engine started to sound like it has a little miss fire, it makes this putting noise but it will only do it when the car starts to get below a half a tank of gas if i feel it completly up it runs like a champ not problems at all, i do not had any cels so i know its not a bad sensor i hope, my first thought it could be my fuel pump is geting weak. if any one has any idea or has experienced this problem befor please let me know, thanks.
  2. Matts96HB
    Matts96HB . Moderator VIP
    Fuel filter? I'd start with the cheap stuff first. The pump could also be on its way out.
  3. rkwoos12
    rkwoos12 New Member
    Kentucky
    already ahead of you
    fuel filter lines are all new only things left if fuel regulator with im 99% its not that and it could be one of the injectors a little stoped up but i been running injector cleaner like crazy in my car and last thing i can think of it that fuel pump
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    fill the car up all the way and set the tripometer and see how far you go before it starts doing that
  5. rkwoos12
    rkwoos12 New Member
    Kentucky
    could moisture or bad gas cause this too? cause my car sat for about three months right befor winter and it could have build up moisture in tank from where it got cold and warm all the time.
  6. AHHVTEC
    Alabama
    not really, unless it was already in the gas
