ALlrite so i have a 91 crx si, with a jdm b18b in it with jdm cable j1 b16 tranny. I am using the stock 91 crx wiring harness on this motor with a pr4 (io believe) ecu.
My air/fuel meter sais i am running EXTREMELY lean, so lean it barely registers, and yes it is hooked up rite, there is only 1 02 sensor wire, cant get it wrong. So i have put in a new fuel filter,Adjustable fuel pressure regulator,02 sensor and still am running extremely lean. ALso am getting a check engine light with code 43 which is fuel system. Can someone please help me diagnose this fucking problem.
I am so stuck and so lost becuase i have thought of as much as i can. ANy way of seeing what kind of injectors i have in there? Keep in my this is all pre-obd,
Any help would be insainely appreciated!.
-dan
-dan
