typesiracing
whats up everone.....just wanna pick some brains....this is my first post but you guys seem really helpfull...any way i have a 94 honda prelude si with crazy mods....i have a je pistons, crower rods the head is ported and polished with jg cams and a 3 angle valve job, the block is bored 40 over, crank is polished, dc 4-2-1 headers, a high flow cat, full custom exhaust, aem cold air intake, msd blaster coil, i also have a jet computer upgrade, well this should be enough info....i'm not trying to brag because the car doesn't even run right to be worth bragging about....i also have a fuel pressure regulator and to get to the point the car smoke black like crazy on accelleration....i tried to bump down the fuel pressure to the point it was below stock....my friend is a honda tech and he told me that the fpr will only change fuel pressure and not the amount of fuel being consumed....so i set it back to stock...i have an air fuel meter and it says i'm running slightly rich which really doesn't do justice to what i see coming out from my exhaust.....the spark plugs have some carbon on them but look kinda white...i'm getting frustrated here.....all the vacuum lines appear to be hooked up and the o2 sensor has just been replaced....i don't know what else to do...i'm thinking apexi afc....but i'm not sure if my mods warrant it and don't wanna waste the money if i don't have to......so maybe someone has had this problem or can help me out.......thanks for you help.
