fuel pump issues
Discussion in 'HYBRID -> EG-EK / DC' started by 97h22dxcoupe, Aug 29, 2009.
  1. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    last week i drove home from work and when i got there shut off the motor it would nt start back up so i replaced the fuel pump and relay and checked fuses still nothing,but my srs light is on could that be my problem ,dont know,if anybody has any ideas for me plz help me out...
  2. Briansol
    srs = airbag. not at all related to the car starting.
    does it crank at all?
  3. 97h22dxcoupe
    Coffeyville, ks.
    yeah it cranks, and i tried running the pump manually to see if it would start still nothing ,but now it just keeps cranking even if i dont have the key in or turned to on position,but the relay is good and pump and fuses still confused ,you got an idea what could fix it ,need serious h e l p !!!!!!!!
  4. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    do you have good grounds
  5. 97h22dxcoupe
    Coffeyville, ks.
    yeah ifound out its the big brown fuse in my fuse box under the hood that has a little plug wire ,it controls all functions for ecu anyways it burnt up(smells really bad) but having a really hard time finding it any where, so does any one know where i can get one??:confused:
  6. Briansol
    honda dealer, hondaautomotiveparts.com
