Fuel pump?....or?
Discussion in 'Civic and del Sol - EG and EK' started by ekRazy, Nov 23, 2008.
  1. ekRazy
    ekRazy New Member
    socal
    I have a 96 HB. It just started making a loud buzzing/humming noise last time I drove it. When I got home I turned the engine off then turned the ignition to the acc position and it still makes it. I was thinking it might be my fuel pump but it still starts fine and doesnt hesitate/bog down when I drive it. Any ideas ??
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    un plug your radio then try it
  3. ekRazy
    ekRazy New Member
    socal
    I do car audio for a living,...its not engine noise from my system. Its even louder standing outside the vehicle. Thank you for the response though.
  4. AHHVTEC
    Alabama
    well the fuel pump don't come on in the acc position
  5. ekRazy
    ekRazy New Member
    socal
    Ok, whatever the key position is right before cranking it over.
  6. AHHVTEC
    Alabama
    that's the on position. if its doing it steady just stick your ear to it, its under the back seat
  7. ekRazy
    ekRazy New Member
    socal
    Ok Ill try that in the morning.
  8. ekRazy
    ekRazy New Member
    socal
    Well I tried listening to it. Now I seriously doubt its my fuel pump because the sound seems its loudest in the front of the car on the drivers side. Any ideas?????:confused:
  9. D16SiHatch
    D16SiHatch New Member
    do you have washer fluid in your reservoir? is the pump somehow permanently on? your cruise control box freakin out maybe? i imagine you would be able to figure out the box if that were the case though since its in plain site. the washer fluid pump however is hidden in your wheel well. off the top of my head i don't know what other electric mechanism in that area of the car could be making a buzzing noise. i mean it does it when the engines off so certainly makes it easier to pinpoint. just keep following the noise till you can determine its location.
  10. ekRazy
    ekRazy New Member
    socal
    I dont have cruise control but Ill check the washer pump in the morning. Thanks alot for the response.
