Fuel pump problem !!!
Discussion in 'HYBRID -> ED-EF / DA' started by stage2mora, Mar 4, 2012.
  1. stage2mora
    stage2mora New Member
    ok i recently bought a walbro fuel pump for my 88 civic ef hatchback. i took off my back seats and looked where the fuel pump normaly is and opened it up but i found nothing... am i gona have to take my Gas tank out to replace my fuel pump ?
  2. RHDism
    RHDism Right Hand Drive guru
    :eek:
    Found nothing? What exactly did you open up?
    Post some pix.
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    yes, need to remove tank
  4. nofxSOHCcrx
    nofxSOHCcrx New Member
    Las Vegas, NV
    I've done it a few times...rather easy to do, just a pain if you have 1/2 a tank or more.
  5. stage2mora
    i dont have a crx thats the problem i took my back seat off and i literaly took off any visable screws like there is a circle one with three start screws i took those off and took the seal off with a flat head and a hammer i opened it up and i just found a floaty thing that i think meassures the gas... but no fuel pump.. i have a ef hatch NOT WAGON
  6. jlicrx
    Colorado Springs
    you cannot access the fuel pump from inside the car - you MUST remove the fuel tank - the CRX and Civic use the same fuel tank and the pump is in the rear of the tank - look at the picture of the fuel tank and read fuel pump "Replacement"
