after i swapped my motor to a b16.. when i turn my key to the ON position my fuel pump relay makes a weird fast pulsating sound..can any1 tell me what that is?
im not sure i think it is bcuzz its making a sound..i check the fues and thats how i found out it was the fuel pump relay cuzz i pulled tht fues and its stopped but as soon as i put it back then its starts again.
i havent turned my key over becuzz i wanted to figure out wut the noise was...now that i noe i cant figure wuts wrong wit it...durin the swap the only thing we took off relatin to the fuel was the fuel line.
Originally posted by civiclxb16@Jan 22 2005, 12:15 AM it is called priming. the pump primes the engine with gas so it can start on the first crank that is all it is
