Fuel pump upgrade?
Johnnylawless
cheked the search function, and saw that if I have larger Injectors ( RC750) that I dont need to upgrade my stock fuel pump?I was going to set it at 60 PSI on the regulator. also see my sig for mods except I will up the boost alot 15-25 psi.
you either read wrong, or searched some shit info.
you need a bigger intank pump. wlbro 255 lhp HP is what you want.... and i hope you have better luck with it than i've been having.
and don't run 60 psi. thats stupid. keep it around 40-45
not to shit on your parade but why an ITR??? why gut it for turbo thereby removing the high compression that really makes it a type r?
Why a type R? GSR and type R motors with turbos fucking kick ass that's why.
EDIT: Oh yeah a walbro 255 will work fine.
went ITR NA'd for awhile and you always crave more power anyways.
Also a cracked ring land on #3 cylinder has prompted me to have it built IB Spec
"Killer Block"
JIM
Does it ever seem like you are saying the same thing over and over?
msd is the only other brand that i know of... for the same style replacement thinkg, and well, msd uses walbro pumps. lol
to my knowledge, they only make inlines... and are thus still limted by tthe stock pump.
