littlecrxVTEC
Well I've got a problem with the fuel pump wiring in my 89 CRX si.
I don't have a FSM so I need a wiring diagram of the fuel pump circuit.
It has a brand new pump installed, and it ran fine until I let her sit for 6 weeks. Then it wasn't getting any power to the pump. I hardwired the pump to the battery to check the pump and it works fine and the car ran.
After that, I tapped into the key on 12v ignition wire with an inline fuse and rewired the power to the fuel pump.
Now wiring is not my best area of DIY knowledge and I'm assuming I bypassed some sort of relay because now the car won't start. Its definately getting fuel into the cylinders but I think that now its flooding itself.
Any help would be greatly appriciated! THANKS
