Finished up the swap to the jdmb16 and now the car cranks but wont start. Theres spark but the fuel pump isn't working. Im stumped and i dont no where to start. please help.
Turn the car on and see if the pump is making any noise. If it isnt, test that baby with the Voltometer. Check your fuel filter and injectors and lines and everything else. It is easy to make mistakes when swapping, just double check all of your work before doing all the hard stuff.
The little circle aluminium cover thats held in by three screws and has one wire connector covers the fuel sending unit, which tells how much fuel there is... this is not the Fuel Pump, to access the fuel pump you must drop the fuel tank. Pretty easy to get to...
