Fuel Pumps?
Discussion in 'Forced Induction' started by Sprocker, Feb 25, 2003.
  1. Sprocker
    Sprocker Senior Member
    What in your opinions is the best and easiest to install fuel pump! Is intank better than inline? I want a nice quiet pump if possible but want o hear what you all think about different pumps! Don't want to have to keep the tank full to avoid noisy pump. Thanks for any suggestions.
  2. civicSiR1
    civicSiR1 Senior Member
    try HKS....they're pretty good....
  3. sisteve
    sisteve Guest
    look no further than a Walbro 255 ltr/hr part # GSS342
    Quiet, Flows, Dependable, Cheap
    You cant go wrong with a walbro.
  4. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    I'm not sure what your set up is, but GSR fuel pumps are good and cheap, if not Walbro is the way to go.
  5. Sprocker
    Ya I have been leaning towards the Walbro but I haven't been able to verify if it works on my car yet, I know they don't list my car on most sites that sell them, also the Walbro is and Intank pump isn't it, how hard to install? I am assuming not too hard.
  6. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    Fuel pumps are easy to install, you dont even need to drop the tank in hondas. Under the rear seat, there is a cover that sits over the fuel pump/sending unit assembly. Take off the cover and pull everything out just like that. Just dont smoke when your doing it .
  7. turborex13
    turborex13 Member
    in a crx you must drop the tank. i run a venom fuel pump. i got it for 189 and i love it. it is also quiet.
  8. D See 2
    D See 2 Senior Member
    Baltimore, MD
    how do you figure? it's right under the rear little compartment thingy. if you dropped it then you had alot more work than needed.
  9. SFPracing
    SFPracing Senior Member
    Miami, Florida
    I agree with Steve.. Walbro is the best, easiest to install and cheapest. Took me 10 mins to put mine in my EK
