b18b1_delsol
I have a b18b1, I am about to boost it and wana get little things out of the way like putting in fuel pump and injectors (450cc)/ resistor box. I will also install the pressure regulator. What pressure do I set it at with just the injectors and pump? Then when I boost it what pressure should i run? Thanks!
