cvcsleeper
Member
I have a 96 DX D16Y7 and I want to swap a 96-98 B18C1 (not sure what year exactly yet), one big issue I had with this swap was that my car didn't have a fuel tank pressure sensor, a bypass solenoid valve, a vent shut valve on the charcoal canister, and a three way valve.
A lot of people mentioned to opt for an OBD1 ECU instead of OBD2. I decided to by a new or used charcoal canister w/ shut valve and 3 way valve from a 98 DX. I've been looking at the diagrams and everything should fit in properly, the only thing I might have to worry about is keeping the canister in place (I'll figure it out).
I also decided to do the same for the fuel tank pressure sensor and the bypass solenoid valve. The 98 DX also has these. I was just wondering if anyone has ever tried this? And if so if they have ever had any problems w/ evap codes or wiring issues.
I know a lot of people will say the I could probably save a lot of money by just re-wiring my OBD2 to an OBD1, but I'd rather have the OBD2 system functioning properly. Let me know what you think of this. Is it a good idea or should I just forget about it?
