Fuel Tank Question!!!!
Discussion in 'HYBRID -> ED-EF / DA' started by ricancivic_91, Nov 4, 2008.
  1. ricancivic_91
    ricancivic_91 New Member
    Hey guys im making it easier for me in which im doing a complete 95 civic obd1 wire hardness swap into my 91 civic hatch. But my question is instead of rewiring the wiring for the fuel pump does anyone know if the 95 civic fuel tank is the same as the 91 civic hatch fuel tank or even fits?
  2. austin20110
    austin20110 New Member
    Northern Va
    same generation isnt it?
    If so dont see why not, but since you have it why dont you just look at it.
  3. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    they are 2 different generations and i dont think it will fit but no sure, if you are swaping the whole harness make sure you check the dash board connectors you may run into a problem with that, i have a 91 and it had a 90 integra harness in it i had to find a stock civic harness to get the dash lights to work properly
