ok i was checking out the zdyne gold setup and one of the features is full throttle shifting. i have no clue what this is or what this does. can someone explain it?
Hondata Website Go there, there's a video. It's pretty much having a chip in your ECU with a rev limiter while the clutch is pressed. So you mash on the gas, and when you clutch in, it only revs up to what you set it to, shift, clutch out.
Quicktime will play in its own standalone player as well- it just works as a plugin to your browser/IE. I don't like playing videos in IE- you can't blow them up full screen. http://www.apple.com/quicktime
