Fully built for boost LS SWAP 100% EVERYTHING CHEAP, M
smooth_criminal
Block (Only 2000miles Yes 2000 miles on all parts)
99’ B18b1
Moroso oil pan w/ oil return bung & oil temp sensor bung
Stock Ls crank micro polished & balanced @ 8500rpms
ACL race main bearing & thrust washers
Clevitte H-series rod bearing
Eagle H-beam rods “ESP†w/ ARP rods bolts
Wiseco Pistons # K542m81 w/ file to fit rings
ACT HDSS Clutch & P-plate
Stock LS Flywheel
New Honda water pump
New Honda Oil pump
New Honda timing belt
ARP Head bolts
Every seal and gasket was replaced with True Honda parts
All sensors are in working condition
Block was assembled by Proformance Unlimited
Chevy crate engines, Ford Crate Engines, Stroker Engines, Muscle Car
Engines
Head (Only 2000 miles after rebuild on head)
99’ ls
Stock Honda head gasket
3 angle valve job
New Honda valve seals
New Honda valve guides
Crower dual stage valve springs
Crower titanium retainers
New Honda valve keepers
Stock LS cams
D-1 Cam cap
Stock Honda dizzy
Stock LS intake manifold
Stock LS fuel rail
B&M Fuel pressure regulator
NGK Plugs & Wires
Every Seal And Gasket was replaced with True Honda parts
Head was assembled by Proformance Unlimited
Engines
Tranny
99’ LS 60k miles
No grinds
Comes with linkage
Slave Cyl
Axles
All sensors are in working order
Misc
Will include OBD2 ECU Even though I highly recommend you running a real EMS system
P/S pump
Alt
Starter
Other misc items
[Looking to get $3500 for this OBO, No corners were cut when building this motor and no expense was spared. If you think what I’m asking is to high shoot me a PM with an offer please don’t whore my post.
I so don’t wanna sell this unit but times are hard and I gotta do what I gotta do to survive
Motor is located in central Jersey 07702, I can ship and have really good rates on shipping. Pick up is more then welcome
Here are a few picks of the motor being built. Will post pic’s of motors current condition once it’s pulled
*Turbo no included but i for sale*
I ran into a finacial down fall and really need to pay up some of my outstanding dept so, i desided that tearing the civic apart and selling it off was my best option.
ripperbone said:
are you going to sell the turbo?
Yes the turbo setup is for sale, Its a greddy 18g freshly rebuilt by majestic turbo only 1500 miles on the turbo. I have the complete kit plus some upgrades for it.
PM me if interested
