Fully Built ZC or b16a1? in a 90 crx si
Discussion in 'HYBRID -> EG-EK / DC' started by THiroshima83, Oct 9, 2002.
  1. Fully built ZC
    100.0%
  2. Stock b1
    0 vote(s)
    0.0%
  1. THiroshima83
    THiroshima83 Member
    what do you guys think
  2. CRX-YEM
    Wallingford, CT
    I'd say go w/ the b16a mainly because there is more support w/ bolt ons and such for that motor
  3. THiroshima83
    THiroshima83 Member
    umm you guys should just take the poll tha'ts why i posted it
  4. phunky.buddha
    Dallas / Fort Worth, TX
    What's your definition of "fully built?"
    If you're planning on never spending any money on the B16's internals, then go with your "fully built" ZC.. depending on what you call "fully built". I'm assuming that you're going to run good intake/header/exhaust with each one, right?
    What you could do with the ZC:
    Higher compression pistons
    Custom ground camshafts (if you can find someone to do it)
    Adjustable cam gears
    Port & polish
    Stronger rods
    And of course the support pieces that you would need for this...
    Compared to a completely stock B16, this setup tuned properly would probably outrun it, not to mention be lighter... but it would also cost more. Then again, you still have to tell us what you mean by "fully built".
    Honestly- I would go with the B16, since there's so much more you can do with one... the aftermarket is plentiful for this engine, and it's just a more solid platform to build on, compared to the ZC.
  5. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    yeah for all we know fully built might mean T3/T4 hybrid
  6. cxjon
    cxjon Senior Member
    man+k+toe
    b16 all the way..... i think i voted for the zc :( by mistake
  7. THiroshima83
    THiroshima83 Member
    The Zc was fully built by Spoon. My friend gave it to them to rebuilt. Spoon cam shafts pistons all the works.
  8. pissedoffsol
    do you have 94 octane gas in your area? cuz if its built by spoon, chances are its 12 :1 easy compression
  9. knowledge
    knowledge Senior Member
    Beale AFB, CA
    I didnt think spoon messed with ZC's. Smells like B.S. to me!
  10. phunky.buddha
    Uh...
    <-- 12.6:1
    <-- Runs just fine on 93 octane.
