Function & Form Coilovers!! Lowest Prices Ever!!
Discussion in 'Vendor Classifieds' started by HiPower Motorsports, Apr 28, 2011.
  1. HiPower Motorsports
    HiPower Motorsports New Member
    HIPOWER MOTORSPORTS NOW CARRIES FUNCTION AND FORM COILOVERS!
    Type 1 Coilovers-
    The Type One Coil-Over is a full bodied coil-over, with simplicity in mind. We set the dampening characteristics for you, and also chose less aggressive spring rates to match the fixed dampening. But what we did not change was the durability, quality, smooth ride, and lowering characteristics we are known for. Continuing with our belief that quality can be affordable, we priced the Type One suspension to fit the financially conscious tuner’s budget. We recommed for the Type One product line for anybody that wants to enjoy performance, quality and great looks in a simplistic way. Install, set your height, and you are ready to roll…!
    Dont let simplicity fool you. The Type One Suspension System is consturcted with the same materials as our Type Two systems. Same approach and philosophy in construction and strength. Our main goal is to give you a peace of mind when commuting, or crusing in the weekend.
    * Adjustable Ride Height
    * Dampening pre-set for optimal ride quality during spirited driving.
    * Adjustable from lower mount, which allows user to retain full shock travel and pre-load adjustments.
    * Dual Tube shock design for maximum ride comfort and durability.
    * Steel construction of lower mounts for increased durability and minimal flex under load.
    * One Year Limited Warranty
    Type 2 Coilovers-
    The Type Two Coil-Over is our flagship full bodied coil-over. More aggressive than the Type One, we aimed to make it the ultimate street inspired coil-over. Our philosphy was a coil-over designer for street durability, comfort, and style, but can endure the occasional track days. A lot of our customers dream of hitting the track, but the reality is they want to enjoy their pride and joy on the streets as well. A dedicated track car is not an easy task many find out. But thats ok, because we designed a suspension that can let you enjoy the streets or an occasional fling on the track. You pick.
    In achieving this, we wanted to make a stronger product to endure the imperfections of the real world. Steel materials have been used for the lower mounts to give the shocks OEM durability. Spring rates are slightly more aggressive than a Type One, to handle occasional track duties and spirited street driving (we always suggest safe and smart driving on public roads). But this did not sacrafice ride quality. Twin tube shocks are used for durability and a smoother ride on the street. Our goal is to offer you a suspension that can handle the wear and tear of daily driving duties. With the Type Two’s 32 levels of dampening adjustment, you can dial in ride and handling characteristics for the street or the track, giving you ultimate versatility.
    Added features:
    * One year warranty.
    * 32 levels of dampening adjustments.
    * Dampening adjustments made with a knob that “clicks” at each level.
    * Steel construction of lower mounts for maximum strength.
    * Adjustable camber plates.
    * Adjustable pillow ball mounts.
    * Adjustable ride height from the bottom mount. [1]
    * Special oil lubrication to withstand conditions from -40 degrees Celsius to 200 degrees Celsius. [2]
    * Dual tube shock design for maximum ride comfort.
    * McPherson strut piston size 50mm.
    * Double wishbone piston size 43mm.
    *Depending on applications.
    [1] This allows the user to retain full shock travel, while being able to lower the car significantly.
    [2] Allowing the shock to perform in even the most demanding environments.
    Free shipping in the United States!
    Pm us for pricing! :D Dont miss out!
  2. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
  3. Ichigo1174
    Ichigo1174 Member
    Florence, SC
  4. HiPower Motorsports
    Bump! No one can touch our prices! We beat everyones prices guaranteed!
  5. HiPower Motorsports
  6. TurboMirage
    do they make these for 93-02 mirages, or 02-06 lancers?
  7. JDMaster
    JDMaster New Member
    how much for the type 2's for a 91 crx shipped to washington?
  8. makewheelies304
    makewheelies304 New Member
    ohio
    how much for the type 1 for a 90 civic hatch back??? im actually lookin for some new coilovers
