Funny Miss
Discussion in 'General Tech and Maintenance' started by Riceburner, Dec 14, 2003.
  1. Riceburner
    Riceburner Senior Member
    Tennessee
    i used a new post so people wouldnt have to search for my question..ok i installed that igniter and it ran fine and still is but sometimes goes back to missin alittle tach doesnt jump or anything just go half throttle and it will stop but heres the kick in the ass..when i reset my computer it quits and doesnt miss all day..but then will go back to alittle miss nothen too big just have to take it half throttle to make it quit..could my ecu be goin bad or could it be my throttle sensor???
  2. Riceburner
    Tennessee
    BumP :blink:
  3. Riceburner
    Tennessee
  4. Riceburner
    Tennessee
  5. 97hatch
    97hatch ?
    Anderson IN
    a low rpm miss could be related to a vacuum leak causing a lean misfire. check all vac lines and look all over manifold for open holes and also spray carb cleaner or starting fluid around head to check intake gasket. If engine reves you have a bad gasket.
  6. statiksol
    statiksol Banned
    try a known good ecu
  7. sleepercivic
    sleepercivic Senior Member
    NC Mountains
    Check your coil, when mine went it boggged/missed a few times then the next night it just died, replaced coil good as new.....
  8. simplyfast
    simplyfast Senior Member
    take the cap off and take sand paper to all the points. give them a good sanding, put everything back together and see if that works.
  9. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    use fine grit(bout +500, i personally use 2000).
  10. Riceburner
    Tennessee
