What up everyone? I recently swapped a b16a into an 88 hf without a problem, but after driving it for about 30 minutes the 50A fuse, which is in the fuse box in the engine compartment, blew out. I replaced the fuse, but it blew out again, this time around 45 minutes(I wasn't actually timing it, just an estimate in case it helps). I was searching online for an answer, but all I got was that the 50A fuse is used for lighting, or at lest was. Any help is appreciated and thx in advance.
