g23 in 92 da
Discussion in 'HYBRID -> ED-EF / DA' started by Clark, Dec 9, 2008.
  1. Clark
    Clark New Member
    does anyone make a mount kit that will fit a f23a1 block h23 head and a d series cable trans fit into an 92 ls integra.
  2. efhondakid
    Akron-Canton, Ohio
    Yeah, you do. That has to be the most off the wall swap that Ive ever heard of.
  3. Clark
    Clark New Member
    its just spare parts i have laying around and wanna tq dd from what i researched it pulls more tq than hp and with the weight of my da it should be pretty nice low revin engine and still pull.
  4. eg6sir
    it'd be much easier to use an H or F series tranny rather than a d-series (dont think thats even possible)..
  5. Clark
    Clark New Member
    i seen bisi had a f to d conversion. the d series trans im using is semi built gear swap and lsd so id like to use that. i also seen a f to b conversion plate aswell. if i got a y80 id just have to use stock trans mounts and a h driverside mount if they even make them for a da
    i think that if i got h22 mounts it should work but i still need to find out what mounts to use for the trans if i use my l3.
  6. eg6sir
    hmm.. learn something new every day... seems as if you know the answer to your question already
