G23 Swap
Discussion in 'HYBRID -> EG-EK / DC' started by johnnyjp3, Dec 30, 2008.
  1. johnnyjp3
    johnnyjp3 New Member
    Well I have seen a couple of people online doing this swap with decent numbers. I just wanted to know if anyone has anyinfo on how to do this swap and what is needed for the swap to run right. I just might sell or trade my 240sx for an ek to do this? Any opinion?
  2. 95b16coupe
    95b16coupe New Member
    ct
    it's not worth it. the power to weight isn't enough for all the custom work.
    check out all the big power honda guys. they use either a b18c or h22.
  3. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    i agree that it is probably not the best idea... if you want to make an all motor beast, then build a b20vtec or a h22, both can make nearly 250whp with the right set up.
    if you want to go fast and stay a little cheaper then turbo is your answer. just pick up whatever b18 your budget allows and boost it, you can make 300 whp on a stock block b18c1 if its tuned right. and the b18a/b motors can make good power with boost too... these ls motors are cheap too.
  4. capslock20
    capslock20 New Member
    1 person likes this.
  5. SlushboxTeggy
    NJ to MA to CA
    I picked up that issue of Import Tuner today. Go figure, I bought it for the cleanest EG hatch I have ever seen that was on the cover.
    But the motor is ridiculous. The only thing is, if it truly begins to gain a following, the cheap parts to build it will not be so cheap anymore.
  6. capslock20
    true that but you can only pick 2, fast, good or cheap. but next to how much a k swap is it is nice. holy shit ya that EG is badass, clean as ever
  7. SlushboxTeggy
    NJ to MA to CA
    I looked at the pic of the engine compartment and was in awe. I mean they even tucked the fan.
    As for the good, fast, cheap... Name one point of that motor that would be the weak link.
  8. sufikation
    sufikation Active Member
    Fruitland, ID
    the tuck was most likely a chasebays job. and for the record i think the g23 is better than a k series, its unique and has potential.
  9. capslock20
    good, not sure how the thing runs, could be blown in a month or 2 but as it seems the guy knew what he was doing
  10. capslock20
    hell ya right there with ya on that one.
  11. 94H_Ex
    94H_Ex Under employed
    Florida
    I wouldnt do it with an Ek, maybe find your self a clean looking 2 dr, 5 spd accord and do the swap on it. But as 95b16coupe says. Its not worth the time and custom work to mount that engine in it.
  12. Korax
    Korax New Member
    Western PA
    How old is this article? I didn't think that Hybrid Dynamics was even around anymore. I thought all the dudes moved to Florida.
  13. 94H_Ex
    Florida
    I dont think its that old really, being that the "G23" concept just came out not too long ago. maybe a couple of months at the least. its been lingering for a while but no one actually called it the "G23" till now.
  14. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just figured id throw this out there the first motor swap honda i ever saw was a v6 crx some 13 years ago
  15. 95b16coupe
    ct
    honda v6 or domestic v6?
  16. AHHVTEC
    Alabama
  17. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I heard about the G23 back around 05...
    The "G23" write-up on HT is from 04..
  18. 94H_Ex
    Florida
    I ve been corrected
  19. SlushboxTeggy
    NJ to MA to CA
    Well this particular "G23" has an F23 block, H22 head, K-series pistons, and a B-series transmission. That alone, just amazes and intrigues me.
  20. Korax
    Korax New Member
    Western PA
    Ah, that makes more sense.
