Gaming Console needs to double as a PC...HELP
Discussion in 'Car Audio / Security / Electronic Accessories' started by d17type-R, Sep 26, 2006.
  1. d17type-R
    d17type-R Doc Brown says
    Langley BC
    I hope I can get some good ideas out of this. I thought it would be totally bithchin if the screen I want to put into my trunk could also have a touch-screen overlay that would control a windows based media center that uses touch icons. There is such a program, that much I know.
    The tricky part comes in where I want to use either a Playstation 2 or XBox 360 and have it double as a PC for the purpose of running said application.
    How do you make a gaming console run a computer program?
    Someone told me that you can use Linux on a PS2.
    If anyone has any bright ideas that'd be killer
    dbadct@hotmail.com
    :D
  2. d17type-R
    Langley BC
    A little feedback please
    :feedback: :toot: Celerity, do you ar any of the other members have any ideas?
  3. BodyDroppedNikes
    caught in a mosh...
    id think that the Xbox 360 would be better suited to serve as a pc rather than a PS2. there is a mobile pc system you can get but i dont know the name of it. google up "mobile pc" and see what you can find.
  4. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
  5. d17type-R
    Langley BC
  6. spikehairboy
    spikehairboy Junior Member
    jsut have it setup so you have differnt inputs 1 computer 2 console sytem. cpu and ram on gaming consoles is sorry
  7. d17type-R
    Langley BC
    the problem with doing it that way is that i'm going to be having almost everything "touch-screen". So being able to switch over to games at the touch of a finger on the screen would look pretty slick in actual operation. That's my whole thing about running just a media center off a console, plus i already have a load of console games
    ^_^
  8. rawerz
    rawerz New Member
    Texas
  9. Sabz5150
    Sabz5150 FALCON PUNCH!!!
    The 360 already suffers from overheating issues, so if he runs an app on that thing full tilt, it'll only end in tears.
    In all honesty, you'd do best running an actual PC instead of a console. More choices for games plus all the apps will run flawlessly. Linux is an excellent choice, there are plenty of frontends for media centers.
    If you want to get *REALLY* slick, you can use MythTV. Have a backend at home, then use a mobile carrier for wireless broadband (not wifi) and stream to your car. Digital cable/Satellite in your car = teh sex.
    Not to mention having all of your DVDs and recorded shows at your fingertips.
  10. d17type-R
    Langley BC
    I have FOUND it!
    :clapping: :laughbounce2: I found the solution to all my woes.... after a lot of Gooooooooogling and tired fingers... I found something that I think is the be all and end all of cool
    http://www.infill.co.kr/eng/products/T3.asp
    Look under Gallery
    and then after looking under Specs.... I see it has monitor support, S/PDIF PCM, and a whole list of other goodies and i can order it from mp3car.com | your source for mobile computing solutions
    Mp3Car.com Custom car computers and parts!
    I MUST HAVE IT!!!!!!!!!!!!!!:D :D :D :D :D :D :D :D
    Plus it looks slick as Eel snot in the dash. Things got brushed aluminum trim... tres sexy.
  11. d17type-R
    Langley BC
    ..... and just in case anyone wondered how you get sound to your amps:
    you use a fiber optic cable and run it to a Clarion DVH-940 5.1 Processor
    Voila! TRUE 5.1 sound. And for added convenience, Clarion also makes a Half-DIN center channel speaker:D
    ....Now all I need to do is rob a bank^_^
