kpeters0929
Member
Garage sale Milwaukee, WI All motor parts/ some turbo parts. Random stuff FS.
FS- UPDATED Today!
Bosch 044 external pump. Comes with bracket and -6an fittings. Has less then 1500 miles on it. Mint cond. $175 picked up or $190 shipped.
RCI 5 gallon fuel cell. part # rci-2050D. You can use either the -8an lines or i'll include a set of -6an fittings. I also have about 20ft. of -6an russell's steel braided lines and an external fuel filter-offer
Selling my fully built b20-v motor. Motor made 549 whp 343 torque at 24psi while peeling out on 4th on the dyno.
Bottom end
'00 b20z2 usdm block
RS machine sleeved 84.5mm
Micropolished Honda crank, all new Honda main/rod bearings, honda thrust washers
Crower 4340 steel Billet rods
JE 9:1 pistons
Block was also hot tanked, and main journals were align honed.
Exedy twin disc clutch for 92+ b-series
head
92 Jdm b16a head
Intake ports were mildly port/polished by DH-racing as well as 5 angle valve job
Ferrea stainless valves
all new Oem honda valve seals
supertech springs/retainers
Cometic head gasket
Golden eagle head studs
Edelbrock victorX manifold
Mr. Gasket fuel rail
68mm billet throttle body
Type r Camshafts with Hayame cam gears.
Motor was built by Mike at Extreme parts in august. Car was tuned on S300 Hondata by Dave at Whipfactory. Motor has less then 3000miles on it. I have all receipts for the motor etc.etc. Motor does not smoke, it has 185compression across the board. Great oil pressure. Only reason i'm selling it is because i wanna do something different in my crx for next year *hint k-series. This engine is basically bullet proof (with the right tuning of course) Price is $4500 with twin disc or $3800 without! What a steal! Motor costed me $10,000+ if your planning on going all out for next year this will save you a lot of $. I did have pictures of the motor getting assembled etc. but i lost them when my computer crashed :crook: pm me if interested or if you would like to check it out in person. Located in Milwaukee, WI.
Mint tenzo bucket seat. No rips, tears, fading etc. If you need a bracket for it i have a few for 92-00 civic's.-$100
Selling MINT 15" rota Jmag's. Bought them about a month ago. You won't see 1 scratch on any of them! They are dirty in the picture, 100% polished. I have all original boxes and center caps for them. 2 of the tires are new g-force bfg's 205/55/15r. I will take off the other 2 tires which are bfg drag radials since i paid a lot for them. All you will need are 2 tires. Paid $550 for them. $499 picked up!
JDM ef8 crx front fog lights. 1 of them is still intact with just a hairline crack in it which you can't notice. Other one is cracked and worthless. Give me an offer on the 1 if you want it.
'97 Type R tranny-Completely Rebuilt by Mike at Extreme parts. Tranny has All new Carbon coated synchros by Gearspeed. 3rd+4th gear sleeve set was replaced with an OEM Honda one. New Honda countershaft and mainshaft top/bottom bearings as well as new seals. Tranny has less then 1500miles on it. Stock Type r LSD with 4.40 Final drive. -$1400 well worth it. Add up the synchros+other parts + labor and your basically getting the tranny for free.
I ALSO have a stock hydro JDM type r tranny for $900
CNC Reverse throw clutch pedal with master cylinder- For all you guys that want to convert your car to true hydrolic this is what you need. All you do is just run your -3an line straight to your clutch slave cylinder-$70
Schedule 40 stainless steel(glass beaded) butt-welded RAM style turbo manifold for b-series. Beautiful manifold, before pic of it glass beaded.. after pic looks nasty since it got all greased up with oil while removing it. Motor made 550whp with this manifold. Has 44mm Tial vband flange on it and it's turbine flange is a t3. It's not ac compatible but you can use power steering (just have to trim the top bracket a little bit) $450
Modified Avid racing traction bar for 88-91 Civic/Crx's. This is what all you turbo guys need if your 3" or even 4" downpipe hits the traction bar. Has mad clearance.$200 + your stock one.
Keizer 2 piece forged aluminum wheels 13". Mounted on them are 24.5" x 8" Mickey's but they are completely worn. Weigh 7.5 lb's each. -$300
RARE '91 LSD Y1 cable JDM tranny. NO grinds. picture of tranny before i installed it on my ef8. '92 JDM b16a engine is also for sale. Bone stock has 65K on it!! Runs great, doesn't burn any oil etc. Come check it out before you buy! I'm looking to sell the complete swap OR i'm willing to part out and sell everything seperately such as the tranny, complete b16 head or block. Throw me some offers or pm me if interested.
88 RHD crx rolling shell. All you need is a motor/tranny. Best reasonable offer.clean registered title. pm me for further details.
Cable b-series halfshaft removed from 91 JDM b16 engine-$40
TI-83plus graphing calcutor, perfect working condition-$25!
88-91 Crx rear bumper, no cracks etc. Has metal plate since the exhaust came off on the right, but you can cover it with a rear lip or something -$25
ecu's-...
obd0 91 pm9-10
obd0 91 pm5-10
obd0 88 pm6-10
obd0 89 pm6-10
obd0 91 pm9-10
obd0 91 pr4-20
obd1 93 pr4-20
obd1 94 p06-20
big yellow wastegate spring for tial 44mm wastegate (7 psi)-$15
92-95 Civic HB door panels-$15 for both picked up! ...they are a dark navy color
Gas pedal from 91 Crx si (will work on all 88-91 Civic/Crx's)-$10
Steering column w/ tilt option for 88-91 Civic/Crx-$30
P72 stock rods $10
JDM b20b AC compressor. Came off of Osaka Jdm motor 30k miles. MINT!! I believe this works with LS integra's as well-$20
95 Gsr power steering pump-$20
95 Gsr power steering pump brackets-$15
95 Gsr alternator brackets (top+bottom)-$10
95 Gsr Honda water pump-$15
95 Gsr Honda timing belt, like new only 10k miles on it-$10
95 Gsr upper/lower alternator brackets-$15
95 Gsr power steering brackets (have an extra 2 but they are just the lower ones)-$5 each
95 Gsr cam gears-$10
92-95 Civic front strut forks-$10
92-95 Civic steering column yoke-$1
94+ Integra drivers side motor mount bracket-$10
90-93 Integra front wheel hubs-$15
88-91 Civic/Crx coin tray-$5
88-91 Civic/Crx radiator T bracket-$10
88-91 Civic Center air vent-$5
88-91 Civic/Crx windshield washer reservoir-$5
88-91 Civic/Crx windshield Cowl-$5
88-91 Civic/Crx windshield wiper arms-$10
88-91 Civic/Crx hood latch-$5
88-91 Civic/Crx tekniq steering wheel hub for sparco steering wheels-$30
88-91 Civic/Crx hood popper-$2
88-91 Civic/Crx power mirror switch (not power folding mirrors)-$2
88-91 Civic/Crx Steering wheel hub for use w/ momo+sparco steering wheels. Brand is Tekniq high quality made in Italy-$30
Cam gears for all b-series. Originally off Ctr cams. -$15 Lowered price $10
92-95 Civic Tenzo-r seat bracket w/ sliders for drivers side- $30 Included is another one i made, doesn't look as good, but still functions perfectly fine.
Msd blaster 2 coil-$25
Msd cap for use w/ external coil for ALL 88-91 ALL Civic/Crx/Integra's-$20
88-91 Civic/Crx fan
94+teg fan
92-00 Civic fan
$20 Each! Lowered price $15 each
Windows-
90-91 Civic Hb- Passenger's door window and passenger's quarter panel
89-91 Crx-Driver's door window *not pictured*
$35 each!
Anyone interested in any parts PM me
FS- UPDATED Today!
Bottom end
JE 9:1 pistons
head
92 Jdm b16a head
Cometic head gasket
ecu's-...
obd0 91 pm9-10
obd0 91 pm5-10
obd0 88 pm6-10
obd0 89 pm6-10
obd0 91 pm9-10
obd0 91 pr4-20
obd1 93 pr4-20
obd1 94 p06-20
P72 stock rods $10
88-91 Civic/Crx fan
94+teg fan
92-00 Civic fan
Windows-
$35 each!
