Garage Sale
Spike
During my quest for a stock B series disc in my garage, I decided to inventory some of the junk we have to see if anyone wants any of it.
1) SOLD
2) GSR drivers side mount
3) GSR stock header upper heat shield(With free bolts!!)
4) GSR stock Intake Manifold (butterflies removed)
5) GSR Flywheel cover and 1 of 2 supporting brackets
6) GSR tranny bracket
7) 4 GSR drivers side mount plastic insert thingys
8 ) P30 power steering bracket
9) 15/16 master cylinder
10) 4 B series PR3 stock cam gears
11) B16 (PR3) back upper cam gear plastic cover(behind the cam gears)
12) B16 (PR3) upper outter cam gear cover
13) PR4 outter cam gear cover (not sure what this will fit, but I will find out)
14) B16 water passage pipe on the back of the block
15) D series Broward 3 puck clutch, needs rebuilding
16) D series Broward disc
17) 1998 Civic EX rear drums
18 ) 1997 SOHC a/c bracket
19) random ass short shifter - aluminum
20) Civic EX front rotors (needs resurfacing)
21) Civic EX cross drilled and slotted front rotors(needs resurfacing)
22) Single gauge pod, black
23) 92-95 Civic Rear LCA's w/o hole for swaybar (one hole was redrilled)
24) Civic front suspension forks, prolly from 92-95 hatch but not sure.
25) 00 Si shiny muffler tip, bling
26) Civic fuel line, from the fuel filter to the fuel rail
27) 95 EX stock fuel pump
28 ) SOLD
29) SOHC shift linkage
30) SOHC drivers side mount(and some other SOHC mounts as well - 98 civic I think)
31) P07 alternator bracket(I assume it is from SOHC)
32) SOHC tranny mount
33) SOHC rear tranny mount
34) SOLD
35) 2 custom/ghetto fabricated nitrous bottle holders. They work and are painted black
36) SOHC distributor cap for external coil
37) Anodized blue oil cap, for all your GAR needs
And I do believe that is all for now, aside from a boatload of wiring and bolts.
Email me at Spikedude2@yahoo.com or AIM "civicdriver22"
#9, the is the brake master cylinder right?
if so, how much?
slowciv1 - GSR drivers side mount - $30 plus shipping.
saturnboy - yes, all parts for the GSR are from 94-00.
I dont know what parts you need prices for. I am just trying to get rid of everything.
*upper heat shield - 7 plus shipping
*intake manifold - 30
*flywheel cover - 10
*tranny lower bracket - 15
93solman - yea, it is a brake master cylinder. I am not sure which model integra it is from.
It has been sitting in the garage along with the rest of the parts for about a year. Looks to be in good condition. Let it go for 25.
sold. get me a shipping quote to Louisville, Colorado, and I'll put a check in the mail to you.
P.S. area code 80026
Drop me an email at Spikedude2@yahoo.com and we can converse over the details there. Or if you have AIM, my name is "civicdriver22". We will just say 30 shipped since shipping will be around 5 to 10 dollars.
If you have paypal, that is the easiest/fastest route to go.
