Gas and Brake Pedal (Integra)
shipsta
I need to know how to take the Gas and Brake pedal out of a 96 integra. I removed all of the bolts that hold the pedal bracket on. What else do I have to do, They won't come out!
You have to unhook the rod that comes through the firewall from the brakebooster to the brake pedal assembly also. There is usually a cotter pin you have to pull and some other crap. Also make sure your brake light switch is unhooked also.
