gas mileage car project
Discussion in 'Civic and CRX - EF' started by seanabekasis, Jun 18, 2010.
  1. seanabekasis
    seanabekasis New Member
    ok i put a d15b6(88 crx hf) into my 91 si hatch. i wired everything except the except the evap system. the map sensor fits in there fine but the sensor right below has 4 wires on the hf and 2 on the si. does anyone no where those wires run to? thanks
  2. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    I am confused by your post.
  3. seanabekasis
    what are you confused about?
  4. eg6sir
    confused about the entire thing.. needs to be cleaned up
  5. wikedeye
    Savannah, Ga.
  6. seanabekasis
    ok i threw in a d15b6 engine into my 91 si hatch. i have all the wiring completed except for the sensor right below the map sensor in the black box on the fire wall. the sensor has 4 wires. i believe red, green, and 2 black/yellow. i need to no where all 4 wires run to. does that help?
  7. eg6sir
    much better.. fixed the first post
  8. seanabekasis
    do you no where they lead to?
  9. eg6sir
  10. chadcharb
    maple valley, Wa
    LOL what a let down
