Gas mileage
Discussion in 'General Tech and Maintenance' started by TurboRex90, Aug 20, 2009.
  1. TurboRex90
    TurboRex90 Golden EG
    Maryland
    So ive been noticing i burn gas quit quickly in my crx.
    I mean i have a 255lph pump, 450cc injectors and run 19psi, but i never really get into it anymore, and if i do its only for a second or two..
    So last time i filled up i made record of my Mileage and then again when i went to fill up, and apparently i get 14mpg.. How is that possible because i know people with twice the size of my injectors making atleast 20mpg.
    Something with the tune maybe? or idk, anyone have any suggestions?
  2. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    the more power you're making the worse your gas mileage will be. so if you want better mileage, turn the boost down
  3. DESPAIN
    flower mound TX
    i get 32 mpg. in my prelude i was runnin 780cc injectors and 255lph... on 9-11 psi. making 270-290whp.
  4. TurboRex90
    Maryland
    Nice try, but My buddy makes 400hp runnin 1000cc injectors gettin more gas milage then me.
    Then look at Despain, soooo idk whats the prob.
  5. 94civicturbo
    94civicturbo New Member
    Liberty, IN
    sounds like my v-8 3/4 ton truck gets the same gas mileage as a honda... now im fuel efficient haha ;)
  6. TurboRex90
    Maryland
    haha. until I figure this nonsense out o_O lol.
  7. 94civicturbo
    Liberty, IN
    try to get a different tune... or somethin idk...
  8. Magana559
    Magana559 The Warden
    fresno Ca
    whats your A/F ratio at WOT, half and partial throttle??
  9. TurboRex90
    Maryland
    if I had an A/F gauge. let alone an O2 sensor I would love to tell you lol. im tuned on no sensor.
  10. DESPAIN
    flower mound TX
    that might be the problem then?
  11. Matts96HB
    Matts96HB . Moderator VIP
    Your problem is shitty tuning. I dunno who in the world would attempt to tune a car based upon feel because it simply doesn't work very well.
    Get a wideband in that thing. My guess is that your AFR's are somewhere in the 11's while cruising at partial throttle, when they really should be somewhere in the 14's. Idle should be higher 14's. Into boost right around the 11.5-12.0 range
  12. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    Wow, you don't even have a gauge much less an o2 sensor? you're probably running way rich.
  13. TurboRex90
    Maryland
    woah guys lol. the guy who tunes it has a wideband plugged into his laptop. so he DID tune it on the dyno with a wideband. the car had run for months fine no probs. so why now over an O2 sensor.
