gas octane
Discussion in 'Civic and CRX - EF' started by valiente, Jun 5, 2008.
  1. valiente
    valiente New Member
    hey i was wondering i did a d16z6 swapped into my ef and was wondering what kind of gas should i use. is regular ok?
  2. E_SolSi
    id stick with 89
  3. efhondakid
    Akron-Canton, Ohio
    ^Yep. Higher octane gas does nothing for a stock motor, and can actually be worse for it in the long run, no to mention harder on your wallet.:D
  4. valiente
    valiente New Member
    cool thanks. one more question how ever im trying to replace the diz and when i pulled it out there was oil coming out of it, is this normal and how much will come out or do i have to drain the oil first.
  5. efhondakid
    Akron-Canton, Ohio
    Yeah it will leak some when you take it out, just put a rag in the hole and check your oil agian when you put it all back together. Its just the oil laying in the top of the head, I would say you wont lose more than half of a quart, but still check and add if need be when its back together.
  6. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it depends on the motor if you need supreme or not but yours will be fine on regular
  7. hope801
    hope801 Active Member
    forget gas octane.
    put in CNG.... it gives u 35 hp
    <_<
